  1. il servizio KlipperScreen. ci sto impazzendo, se guaro il log di klipperscreen, e ti allego qui il pezzetto interessante 2023-12-13 23:14:21,257 [functions.py:log_start()] - --------------------KlipperScreen Log Start-------------------- 2023-12-13 23:14:21,258 [functions.py:log_start()] - KlipperScreen Version: v0.3.7-10-gdd3b255-dirty 2023-12-13 23:14:21,258 [functions.py:log_start()] - Python version: 3.9 2023-12-13 23:14:21,402 [config.py:get_config_file_location()] - Passed config (-c): /home/biqu/KlipperScreen.conf 2023-12-13 23:14:21,403 [config.py:__init__()] - Config path location: /home/biqu/KlipperScreen.conf 2023-12-13 23:14:21,436 [config.py:log_config()] - ===== Config File ===== come vedi il KlipperScreen.conf lo trova nel path dove l'ho messo io, poi più in basso sempre nel log.... 2023-12-13 23:16:38,557 [screen.py:_load_panel()] - Loading panel: bed_level 2023-12-13 23:16:38,572 [bed_level.py:_get_screws()] - bed_screws 2023-12-13 23:16:38,573 [bed_level.py:_get_screws()] - screw1: 30, 30 2023-12-13 23:16:38,575 [bed_level.py:_get_screws()] - screw2: 210, 30 2023-12-13 23:16:38,575 [bed_level.py:_get_screws()] - screw3: 30, 210 2023-12-13 23:16:38,575 [bed_level.py:_get_screws()] - screw4: 210, 210 2023-12-13 23:16:38,576 [bed_level.py:_get_screws()] - screw5: 115, 115 2023-12-13 23:16:38,576 [bed_level.py:__init__()] - bed_screws: [[30.0, 30.0], [210.0, 30.0], [115.0, 115.0], [30.0, 210.0], [210.0, 210.0]] 2023-12-13 23:16:38,576 [bed_level.py:__init__()] - X: {210.0, 115.0, 30.0} Y: {210.0, 115.0, 30.0} 2023-12-13 23:16:38,577 [bed_level.py:__init__()] - Using max_distance: 85 to fit: 5 screws. 2023-12-13 23:16:38,577 [bed_level.py:__init__()] - Using 5/5-screw locations 2023-12-13 23:16:38,659 [screen.py:attach_panel()] - Current panel hierarchy: main_menu > more > bed_level ci trovo questo pezzetto che riduarda il bed level manuale con la posizione delle viti, che è esattamente ciò che gli ho infilato io nel conf... e quindi.... perché da monitor non funziona? Se tappo su bed level nel menu del display mi da "Not supported for auto-detection" e poi mi dice "This message will appear if you are using 3 or 5 screws and didn't define them in KlipperScreen.conf. See "screw_positions" in the printer options" peccato che io in KlipperScreen.conf sta roba l'ho definita.... e questo è il .conf KlipperScreen.conf
  2. Ok se ne sbatte.... quindi? gli cambio directory?
  3. Adesso sta solo in /KlipperScreen/ ed il servizio da Fluidd si può riavviare senza compromettere la stampa in corso quindi ora sta solo nella seconda della lista e lo dovrebbe unire al defaul.conf che ha già (perché se lo è creato in installazione) Vedremo se lo fa quando termina la stampa
  4. Qualcuno mi dice per quale motivo KlipperScreen.conf se ne sbatte delle modifiche che gli faccio? https://klipperscreen.readthedocs.io/en/latest/Configuration/#klipperscreen-behaviour-towards-configuration qui dice dove va a cercare il file di configurazione KlipperScreen.conf nelle varie directory.... io ho messo sto cavolo di KlipperScreen.conf praticamente in tutte quelle citate ma a quanto pare se ne sbatte... ed io non riesco a fare il livellamento del piatto dal monitor... la cosa mi da alquanto fastidio
  5. molto bene
  6. no scusa era questo https://www.thingiverse.com/thing:3102082 guarda il video in fondo che fa vedere come soffia
  7. Hai visto il terzo che ho postato? c'è anche un video, guardalo 😉
  8. ogni buon smanettone ha aperto la sua stampante per conoscerne i più reconditi segreti... 😄
  9. eccolo l'ho trovato quello che sto usando adesso https://www.thingiverse.com/thing:3495189
  10. al momento direi che riesce a raffreddarlo bene, anche perché non sto usando il soffiatore originale, sto usando uno tirato giù da TV che ora non riesco a ritrovare ma che è abbastanza simile a questo https://www.thingiverse.com/thing:4234118 ma se vedo che non è più sufficiente posso pensare di passare a queste altre soluzioni https://www.thingiverse.com/thing:3102082 https://www.thingiverse.com/thing:4813347
  11. potrei consigliarti un carrello di X un po' migliore di questo che vedo? non la prendere come una offesa se l'hai progettato tu.. https://cults3d.com/en/3d-model/various/the-diamond-mount-direct-drive-hotend-mount-for-v6-nf-smart-dragon-dragonfly-zodiac-bmo-and-more-sapphire-pro-sp-3-plus-sp-5-printers-laurienzudesign-2 questo va su guide lineari 😉 magari ha una migliore distribuzione del peso
  12. no decisamente non è normale che faccia quelle "onde", deve fare così: e se non lo fa allora qualcosa nella scheda di controllo o nel tipo di termistore dichiarato in Klipper non va bene
  13. a che velocità stampi? a me viene in mente un po' di gioco su qualche asse, probabilmente X
  14. no penso che per il momento terrò la configurazione semi originale. Mi interessa la velocità ma non così estrema, già adesso in bowden la Ender 3 va 160mms quando con Marlin non aveva mai superato i 60/70, mi posso ritenere già più che soddisfatto.
  15. stasera lo sei stato 😉
  16. p.s il bt non mi interessa sei un angioletto 😄
  17. le misure dovrebbero essere uguali a quelle del bmg classico
  18. ok tu hai fatto pesanti modifiche ma io ho in mente un'altra cosa per tenerlo leggero e mantenre la tua idea di impostazione... per prima cosa non utilizzerò il BMG classico ma questo https://it.aliexpress.com/item/33029933418.html?gatewayAdapt=glo2ita e poi manterrò la sua gabbietta per adesso prima che io lo stampi mi ci puoi fare il quarto buco? 🙂
  19. si ma se guardi la foto dello schermo da Heater ID:0 e quello è il termistore dell'hotend sono i termometri che rilevano la temperatura
  20. non è il termistore del bed, è quello dell'hotend 😉
  21. hai detto che si è sciolto fino al rame, quindi è possibile che sia andata in corto la schedina interna quella che si vede nella foto 2
  22. facci una foto anche a questo benedetto DD della Ender 3 😉
  23. non ti credere già lo faccio ho anche il tablet dedicato, ed anche un cellulare un po' datato e le 2 Titan sono attaccate ad un portatile, è solo che esteticamente mi piacciono di più con il display, te l'ho detto sono all'antica 😉 e ti dirò di più... su tutti, portatile e BTTPi ho installato Zerotier, così le controllo anche da remoto quando non sono a casa, si lo so non me lo dire c'è Obico in Kiauh, l'ho provato e non mi piace per niente, con zerotier invece resto con il mio fluidd
  24. perché sono all'antica... ho sempre avuto un display attaccato alla stampante e mi piace così 😄
  25. E allora non usi nemmeno il tft35 SPI...
