Tutti i contenuti di Joker78
si si ho lo splitter prima usavo queste impostazioni, meglio o peggio di come mi consigli? //#define AUTO_BED_LEVELING_3POINT //#define AUTO_BED_LEVELING_LINEAR #define AUTO_BED_LEVELING_BILINEAR //#define AUTO_BED_LEVELING_UBL //#define MESH_BED_LEVELING /** * Normally G28 leaves leveling disabled on completion. Enable * this option to have G28 restore the prior leveling state. */ //#define RESTORE_LEVELING_AFTER_G28 /** * Enable detailed logging of G28, G29, M48, etc. * Turn on with the command 'M111 S32'. * NOTE: Requires a lot of PROGMEM! */ //#define DEBUG_LEVELING_FEATURE #if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL) // Gradually reduce leveling correction until a set height is reached, // at which point movement will be level to the machine's XY plane. // The height can be set with M420 Z<height> #define ENABLE_LEVELING_FADE_HEIGHT // For Cartesian machines, instead of dividing moves on mesh boundaries, // split up moves into short segments like a Delta. This follows the // contours of the bed more closely than edge-to-edge straight moves. #define SEGMENT_LEVELED_MOVES #define LEVELED_SEGMENT_LENGTH 5.0 // (mm) Length of all segments (except the last one) /** * Enable the G26 Mesh Validation Pattern tool. */ #define G26_MESH_VALIDATION #if ENABLED(G26_MESH_VALIDATION) #define MESH_TEST_NOZZLE_SIZE 0.4 // (mm) Diameter of primary nozzle. #define MESH_TEST_LAYER_HEIGHT 0.2 // (mm) Default layer height for the G26 Mesh Validation Tool. #define MESH_TEST_HOTEND_TEMP 205.0 // (°C) Default nozzle temperature for the G26 Mesh Validation Tool. #define MESH_TEST_BED_TEMP 60.0 // (°C) Default bed temperature for the G26 Mesh Validation Tool. #endif #endif #if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR) // Set the number of grid points per dimension. #define GRID_MAX_POINTS_X 6 #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X // Set the boundaries for probing (where the probe can reach). //#define LEFT_PROBE_BED_POSITION MIN_PROBE_EDGE //#define RIGHT_PROBE_BED_POSITION (X_BED_SIZE - MIN_PROBE_EDGE) //#define FRONT_PROBE_BED_POSITION MIN_PROBE_EDGE //#define BACK_PROBE_BED_POSITION (Y_BED_SIZE - MIN_PROBE_EDGE) // Probe along the Y axis, advancing X after each column //#define PROBE_Y_FIRST #if ENABLED(AUTO_BED_LEVELING_BILINEAR) // Beyond the probed grid, continue the implied tilt? // Default is to maintain the height of the nearest edge. //#define EXTRAPOLATE_BEYOND_GRID // // Experimental Subdivision of the grid by Catmull-Rom method. // Synthesizes intermediate points to produce a more detailed mesh. // //#define ABL_BILINEAR_SUBDIVISION #if ENABLED(ABL_BILINEAR_SUBDIVISION) // Number of subdivisions between probe points #define BILINEAR_SUBDIVISIONS 3 #endif #endif #elif ENABLED(AUTO_BED_LEVELING_UBL) //=========================================================================== //========================= Unified Bed Leveling ============================ //=========================================================================== //#define MESH_EDIT_GFX_OVERLAY // Display a graphics overlay while editing the mesh #define MESH_INSET 1 // Set Mesh bounds as an inset region of the bed #define GRID_MAX_POINTS_X 10 // Don't use more than 15 points per axis, implementation limited. #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X #define UBL_MESH_EDIT_MOVES_Z // Sophisticated users prefer no movement of nozzle #define UBL_SAVE_ACTIVE_ON_M500 // Save the currently active mesh in the current slot on M500 //#define UBL_Z_RAISE_WHEN_OFF_MESH 2.5 // When the nozzle is off the mesh, this value is used // as the Z-Height correction value. #elif ENABLED(MESH_BED_LEVELING) //=========================================================================== //=================================== Mesh ================================== //=========================================================================== #define MESH_INSET 10 // Set Mesh bounds as an inset region of the bed #define GRID_MAX_POINTS_X 3 // Don't use more than 7 points per axis, implementation limited. #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X //#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest Z at Z_MIN_POS #endif // BED_LEVELING /** * Points to probe for all 3-point Leveling procedures. * Override if the automatically selected points are inadequate. */ #if ENABLED(AUTO_BED_LEVELING_3POINT) || ENABLED(AUTO_BED_LEVELING_UBL) //#define PROBE_PT_1_X 15 //#define PROBE_PT_1_Y 180 //#define PROBE_PT_2_X 15 //#define PROBE_PT_2_Y 20 //#define PROBE_PT_3_X 170 //#define PROBE_PT_3_Y 20 #endif /** * Add a bed leveling sub-menu for ABL or MBL. * Include a guided procedure if manual probing is enabled. */ //#define LCD_BED_LEVELING #if ENABLED(LCD_BED_LEVELING) #define MBL_Z_STEP 0.025 // Step size while manually probing Z axis. #define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS for LCD Z adjustment #endif // Add a menu item to move between bed corners for manual bed adjustment //#define LEVEL_BED_CORNERS #if ENABLED(LEVEL_BED_CORNERS) #define LEVEL_CORNERS_INSET 30 // (mm) An inset for corner leveling #define LEVEL_CORNERS_Z_HOP 4.0 // (mm) Move nozzle up before moving between corners //#define LEVEL_CENTER_TOO // Move to the center after the last corner il motore estrusore è ha sinistra monto il bowden da 600mm
Scusa volevo rispondere a iov3bite Si scusa allora ti ho risposto in privato ma ho sbagliato, uso un driver per due motori su z, cosa è il bed tramming?
Sto seguendo questa guida, però vedo che nel video fa diversamente 🤔 apperte il monitor che non dovrei aver bisogno di modifiche perché il mio 1268 è la versione con la micro sd, con i pin già girati e dovrebbero tornare, per il resto è tutto uguale, a questo punto se riuscivo, volevo togliere i microswitch, lo aggiungerò in futuro per l'asse z
Mi rispondo da solo è per altre schede madri
ok grazie
ok speriamo
Aggiornamento sono riuscito ha configurare la scheda, inizio ha capire come funziona il programma, rimane comunque la parte più rognosa il configuration.h, devo riuscire ha capire come impostare alcuni punti, per esempio io uso il classico lcd 1268 mi ricordo che con arduino si doveva scaricare u8glib, e con visualstudio? intanto mentre aspetto faccio un po di pratica, anche perchè se voglio continuare a stampare devo imparare ad usare le 32bit
Ti ringrazio veramente, credimi non lo fo per sfizio, sto in queste condizioni perché se bruciata, tra l'altro mi mando delle calie micidiali, avevo risposto una decina di giorni fa in un post dove dicevo se la dovessi ricomprare anche io prenderei una 32 bit, tempo 10 giorni e bruciata, cosa strana che è andato in cortocircuito la resistenza del nozle, infatti ha preso fuoco proprio da dove prende corrente sulla scheda, sinceramente non credevo si potesse bruciare così, pensavo che questo genere di problemi interessasse più il bed.
Ti ringrazio vedrò di fare così. Infatti mi sa che ho i tuoi stessi problemi, se solo quando uscirono le 32 bit mi fossi messo ha leggere i vari post oggi partirei avvantaggiato solo che non credevo l'avrei mai cambiata.
intanto ti ringrazio veramente, credimi non la voglio cambiare per sfizio, solo che la msk 8bit si è bruciata e quando sono andato per riprenderla mi costava più di una 32 bit, altrimenti mi sarei tenuto quella per molto molto altro tempo ancora, anche perchè per quello che stampo mi andava benissimo. la stampante è una sola è una ctc i3 pro b, modicata diciamo che è uguale ha una geeetech stile prusa, oppure la anet a8 la macchina è uguale differisce poco, pero' visto che ho ancora i file configuration.h e adv del marlin 1.1.9 te li mando per posta, almeno sono una partenza, la differenza sta nella scheda che adesso è una skr 1.3 e monto i tmc2209 di cui non mi importa metterli in uart, per il momento mi accontento di farli funzionare in maniera stock. cosi almeno salvo il firmware e l'ho metto da parte.
niente non ne vengo a capo, per oggi lascio stare mi conviene riordinare una mks gen1.4 e fine del chiasso.
ti voglio bene ❤️ ☺️ grazie praticamente l'ho fatto io ma adesso sento puzza di bruciato provenire dal mio cervello, certo è tre giorni che spulcio e non ci sto a capi una mazza
allora non riesco a fare il build mi da questo errore Error: Unknown environment names 'lpc1768'. Valid names are 'STM32F103RC_fysetc, at90usb1286_dfu, mks_robin_e3p, mks_robin_nano_v3_1_usb_flash_drive, mks_tinybee, LERDGEX, mks_robin_e3_maple, mks_monster8_usb_flash_drive, teensy20, mks_robin_mini_maple, teensy41, STM32F103RC_btt_USB, melzi_optiboot, STM32G0B1RE_btt_xfer, STM32F103VE_GTM32_maple, mega2560ext, linux_native, STM32F070CB_malyan, trigorilla_pro, STM32F070RB_malyan, BIGTREE_OCTOPUS_PRO_V1_F429_USB, REMRAM_V1, mks_robin_lite, STM32F103RC_fysetc_maple, STM32F103VC_ZM3E4_USB_maple, mks_robin_nano_v3_usb_flash_drive, PANDA_PI_V29, STM32F401VE_STEVAL, mks_robin_nano_v3_usb_flash_drive_msc, STM32F103RC_meeb_maple, chitu_f103_maple, BIGTREE_SKR_PRO, simulator_linux_release, mks_robin_lite3, jgaurora_a5s_a1, ARMED, STM32F401RC_creality, STM32F103RC_btt_512K, LPC1769, STM32F103RET6_creality_xfer, STM32F103VC_ZM3E4_USB, STM32F103VE, PANDA, STM32F103CB_malyan_maple, mks_monster8_usb_flash_drive_msc, BIGTREE_OCTOPUS_V1, mks_robin_e3, jgaurora_a5s_a1_maple, BIGTREE_OCTOPUS_PRO_V1_F429, mks_robin_lite3_maple, mks_robin_pro_maple, STM32F103RE_creality_smartPro, LERDGEK_usb_flash_drive, Index_Mobo_Rev03, BIGTREE_BTT002, STM32F103CB_malyan, FLY_MINI, mks_robin_nano_v1_3_f4, STM32F401RC_creality_stlink, STM32F103RET6_creality_maple, malyan_M300, teensy31, mingda_mpx_arm_mini, FYSETC_CHEETAH_V20, STM32G0B1RE_btt, STM32F103RC_btt_512K_USB_maple, simulator_linux_debug, MightyBoard1280, mks_robin_e3p_maple, mks_robin_nano35_maple, mks_robin_pro, BIGTREE_E3_RRF, simulator_macos_release, STM32F103RC_creality_xfer, LERDGES, LERDGEX_usb_flash_drive, STM32F103RC_meeb, STM32F103VE_GTM32, STM32F103RC_btt, include_tree, chitu_v5_gpio_init_maple, FLY_MINI_maple, mks_robin_pro2, MightyBoard2560, chitu_f103, DUE_USB, DUE, STM32F103VE_longer_maple, STM32F103RE_creality, mega1280, trigorilla_pro_maple, mks_eagle_usb_flash_drive_msc, STM32F103RC_creality, BIGTREE_SKR_2_USB_debug, LERDGEK, mks_robin_nano_v3_1_usb_flash_drive_msc, mks_robin_nano_v3_1, TH3D_EZBoard_V2, rambo, DUE_archim, STM32F103RC_maple, STM32F103VE_ZM3E4V2_USB, STM32F103RE, STM32F103ZE, mks_monster8, FYSETC_E4, STM32F103RE_creality_smartPro_maple, STM32F103RC_btt_USB_maple, STM32F103RC_ZM3E2_USB_maple, mks_eagle_usb_flash_drive, FYSETC_F6, mks_robin_mini, STM32F103VE_longer, BIGTREE_GTR_V1_0_usb_flash_drive, NUCLEO_F767ZI, mks_robin_maple, SAMD51_grandcentral_m4, STM32F103RE_creality_maple, simulator_macos_debug, at90usb1286_cdc, teensy35, teensy36, sanguino644p, STM32F407VE_black, mks_robin, chitu_v5_gpio_init, FYSETC_S6_8000, BIGTREE_OCTOPUS_V1_USB, STM32F103RC_btt_512K_maple, STM32F103RC_ZM3E2_USB, mega2560, STM32F103RE_btt_USB_maple, ERYONE_ERY32_MINI_maple, BIGTREE_BTT002_VET6, melzi_optiboot_optimized, STM32F103RE_maple, simulator_windows, STM32F103RE_btt, BIGTREE_SKR_2_F429_USB_debug, Artillery_Ruby, esp32, STM32F103RET6_creality, STM32F103RC_creality_maple, FYSETC_S6, STM32F103RE_creality_xfer, Anet_ET4_OpenBLT, FLYF407ZG, BIGTREE_SKR_2_F429, STM32F103VE_ZM3E4V2_USB_maple, STM32F103RC_btt_maple, mks_eagle, sanguino1284p, rumba32, BIGTREE_GTR_V1_0, melzi_optimized, melzi, STM32F103RC_btt_512K_USB, BIGTREE_SKR_2_F429_USB, mks_robin_lite_maple, STM32F103RE_btt_USB, mks_robin_nano35, BIGTREE_SKR_2, BIGTREE_SKR_PRO_usb_flash_drive, BIGTREE_SKR_2_USB, BTT_SKR_SE_BX, STM32F103RE_btt_maple, sanguino1284p_optimized, LPC1768, flsun_hispeedv1, LERDGES_usb_flash_drive, mks_robin_nano_v3, STM32F401RC_creality_jlink' perche'? eppure ho selezionato la scheda giusta
l'ho notato pero nel 2.0 le cordinate x e y sono insieme invece prima prendeva in riferimento le cordinate di y e sotto l'altra riga cera x, siccome io devo solo modificare x a +24mm e non y, per questo mi trovo in difficoltà, non era più semplice prima? in pratica cosa dovrei scrivere in quella voce 0 e +24?
si ma almeno arduino è più intuitivo, visualcode con platformio non girano bene su win10 64bit da un sacco di problemi ho dovuto istallarlo su win7 32bit, avrai ragione non lo metto indubbio mi spiace perche ormai arduino avevo imparato le varie voci, per esempio adesso non so piu' come fare per far capire alla stampante che la sonda è a sinistra del nozzle di 24mm, prima era cosi semplice ora mi sembra complicato, sarò asino io non lo metto indubbio solo che i termini delle stringhe sono cambiate quasi tutte
non capisco come fate a dire che visualstudio sia migliore di arduino, un programma fatto con i piedi pieno di bug.
Istallato, dalla versione 1.1.9 alla 2.9.3 c'è un mondo di differenza......ciao core.....
Sempre tramite visual studio? Comunque ero abituato con Arduino e con visual studio non ci capisco una mazza Ma con Arduino è impossibile fleshare una 32bit giusto?
Problemi di stampa Artillery Hornet
Joker78 ha risposto a daniele13 nella discussione Problemi generici o di qualità di stampa
Si questo succede se hai le molle dure, sono regolazioni di fino che all'inizio portano via molto tempo. -
Se usi marlin credo mi pare di sì, però va abilitato via firmware -
Si, potrebbero essere le molle del bed che non sono dure addastsnza, comunque se leggi quasi tutti i sensori per livellare non sono precisi, che sia un problema legato al sensore o al marlin? non lo so ma leggendo è un problema che riscontrano in molti. -
Grazie mille.
Salve a breve monterò una BTT SKR 1.3 con tmc2209, anzi con l'occasione ringrazio già @MAL1190 che me l'ha venduta, vengo al dunque, siccome prima di questa avevo una msk 8bit, con il marlin 1.1.9 vorrei passare al marlin 2.x.x come faccio a passare le impostazioni che ho salvato sul marlin2.x.x? Devo utilizzare visual studio e cambiare stringa per stringa?
