adfdzfad Inviato 4 ore fa Inviato 4 ore fa 📞+1 - 854 - 247 - 8515 Many users get worried when a transaction shows as pending in Trust Wallet. 📞+1 - 854 - 247 - 8515 If you are facing the same issue, don’t panic. Here is a deep, 📞+1 - 854 - 247 - 8515 simple, and user-friendly guide explained 📞+1 - 854 - 247 - 8515 number-wise to help you understand what you can and cannot do. 📞+1 - 854 - 247 - 8515 1. First, understand what “pending” means 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 A pending transaction means your transfer has already been sent to the blockchain, 📞+1 - 854 - 247 - 8515 but it has not yet been confirmed by the network. 📞+1 - 854 - 247 - 8515 Trust Wallet does not control the transaction once it is broadcast. 📞+1 - 854 - 247 - 8515 2. Know the most important truth 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 You cannot directly cancel a pending transaction inside Trust Wallet. 📞+1 - 854 - 247 - 8515 This is because blockchain transactions are decentralized and irreversible once submitted. 📞+1 - 854 - 247 - 8515 3. Check your transaction status properly 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 Open Trust Wallet → tap the transaction → copy the transaction hash → open the blockchain explorer link. 📞+1 - 854 - 247 - 8515 This 📞+1 - 854 - 247 - 8515helps you confirm whether the transaction is truly pending or already processed 📞+1 - 854 - 247 - 8515. 4. The only possible way to stop it (advanced method) 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 If your transaction is stuck and uses a network like Ethereum or BNB Smart 📞+1 - 854 - 247 - 8515 Chain, you may try to replace the transaction using the same wallet address and the same nonce with a higher gas fee. 📞+1 - 854 - 247 - 8515 This method is called “speed up” or “replace transaction.” 📞+1 - 854 - 247 - 8515 5. Increase the gas fee to push a new transaction 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 Send a new transaction to your own wallet address using the same nonce and a higher gas fee. 📞+1 - 854 - 247 - 8515 If the network accepts the new one first, the old pending transaction may be dropped. 📞+1 - 854 - 247 - 8515 6. Wait if you are not familiar with nonces 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 If you are not experienced with advanced settings, the safest option is to wait. Most pending transactions automatically fail or confirm once network traffic becomes normal. 📞+1 - 854 - 247 - 8515 7. Do not trust fake cancel services 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 There is no official service that can cancel a Trust Wallet transaction for you. Any website or person claiming this is likely a scam. 📞+1 - 854 - 247 - 8515 8. Prevent this problem in the future 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 Always select the correct network, avoid using extremely low gas fees, and confirm all details before tapping “Send.” 📞+1 - 854 - 247 - 8515 9. Final reminder 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 Trust Wallet is only a wallet interface. 📞+1 - 854 - 247 - 8515 It cannot reverse or cancel blockchain actions. 📞+1 - 854 - 247 - 8515 Understanding this saves you from unnecessary stress and losses. 📞+1 - 854 - 247 - 8515 📞+1 - 854 - 247 - 8515 By following these steps, you can safely handle pending transactions and avoid common mistakes in Trust Wallet. 📞+1 - 854 - 247 - 8515 Cita
