adfdzfad Inviato 9 ore fa Inviato 9 ore fa +1 - 854 - 247 - 8515 Your Coinbase wallet address is the destination where others can send you cryptocurrency. +1 - 854 - 247 - 8515 To find it, open the Coinbase app or website and sign in. Tap on Assets, then select the specific crypto you want to receive,+1 - 854 - 247 - 8515 Â such as Bitcoin or Ethereum.+1 - 854 - 247 - 8515 +1 - 854 - 247 - 8515Next, click or tap Receive. +1 - 854 - 247 - 8515You will instantly see your wallet address along with a QR code. +1 - 854 - 247 - 8515 This address is unique to that cryptocurrency and should only be used for that specific asset. +1 - 854 - 247 - 8515For example, a Bitcoin address must only receive Bitcoin. +1 - 854 - 247 - 8515 +1 - 854 - 247 - 8515 You can copy the address directly from the screen and share it with the sender.+1 - 854 - 247 - 8515 Â If you are using the Coinbase Wallet app, the process is similar: choose the asset, select Receive, and your address will appear. +1 - 854 - 247 - 8515 +1 - 854 - 247 - 8515 For safety, always share your address using the copy button instead of typing it manually. +1 - 854 - 247 - 8515 Even a small mistake can cause your funds to go to the wrong place. +1 - 854 - 247 - 8515 Keeping this habit ensures smooth and secure transactions every time. +1 - 854 - 247 - 8515 Cita
