palatua30 Inviato 4 ore fa Inviato 4 ore fa If Norton is charging your credit card and you want to stop it,📞 (+1)802-557-0358 the most common reason is that automatic renewal is turned on for your 📞 (+1)802-557-0358 Norton subscription📞 (+1)802-557-0358 Norton enables auto-renewal by default so your protection continues without interruption, but you can disable it at any time📞 (+1)802-557-0358 Here’s how you can stop Norton from charging your card📞 (+1)802-557-0358 1📞 (+1)802-557-0358 Turn Off Norton Automatic Renewal The easiest and most effective way is to disable auto-renewal from your Norton account: Go to the Norton official website and sign in to your account📞 (+1)802-557-0358 Open My Subscriptions or Billing Information📞 (+1)802-557-0358 Find your active Norton subscription📞 (+1)802-557-0358 Click Cancel Renewal or Turn Off Auto-Renewal📞 (+1)802-557-0358 Confirm your choice📞 (+1)802-557-0358 Once auto-renewal is turned off, Norton will not charge your credit card again, and your protection will continue until the current subscription expires📞 (+1)802-557-0358 2📞 (+1)802-557-0358 Remove or Update Payment Method You can also stop future charges by removing your credit card details: Log in to your Norton account Go to Billing / Payment Methods Remove your saved credit card or replace it with another payment method This prevents Norton from automatically billing your card📞 (+1)802-557-0358 3📞 (+1)802-557-0358 Check for Recent Charges and Refund Eligibility If Norton has already charged your credit card, you may be eligible for a refund📞 (+1)802-557-0358 Norton usually offers a refund window (often 30–60 days, depending on the plan)📞 (+1)802-557-0358 You can request a refund through your Norton account or by contacting Norton customer support directly📞 (+1)802-557-0358 4📞 (+1)802-557-0358 Contact Norton Customer Support If you’re unable to cancel auto-renewal online or see unexpected charges, contacting Norton support is recommended📞 (+1)802-557-0358 They can: Cancel your subscription Stop future charges Process refunds if eligible 5📞 (+1)802-557-0358 As a Last Resort: Contact Your Bank If you cannot reach Norton or believe the charge is unauthorized, you can contact your credit card issuer to block future charges from Norton📞 (+1)802-557-0358 However, this should be a last step, as it may interrupt active services📞 (+1)802-557-0358 Final Thoughts To stop Norton charging your credit card, always disable auto-renewal through your Norton account📞 (+1)802-557-0358 Review your billing settings regularly to avoid surprise renewals, and act quickly if you want a refund after a charge📞 (+1)802-557-0358 Cita
