palatua30 Inviato 4 ore fa Inviato 4 ore fa If you switch to a new device, Norton allows you to reactivate your subscription easily. 📞 (+1-)802-557-0358 Simply sign in to your Norton account, remove the old device if needed, and install Norton on the new device. The subscription 📞 (+1-)802-557-0358 will activate automatically without needing a new product key, as long as your plan supports multiple devices. Norton Activation FAQs What is Norton activation? Norton activation is the process of enabling your Norton antivirus subscription 📞 (+1-)802-557-0358 so that all security features work fully on your device. Where do I activate Norton? You📞 (+1-)802-557-0358 can activate Norton by visiting norton.com/setup and signing in to your Norton account. Do I need a product key for Norton activation? A product key is required if you purchased Norton from a retail store. 📞 (+1-)802-557-0358 Online purchases are usually linked directly to your Norton account. Can I activate Norton on multiple devices? Yes, if your subscription supports multiple devices, 📞 (+1-)802-557-0358 you can activate Norton on more than one device using the same account. How do I know if Norton is activated? Open the Norton app and check the subscription status. 📞 (+1-)802-557-0358 If it shows active protection and an expiry date, Norton is activated. What should I do if Norton activation fails? Check your internet connection, verify the product key, 📞 (+1-)802-557-0358 ensure you are using the correct email account, and try reinstalling Norton. Cita
