mongoose Inviato 1 ora fa Inviato 1 ora fa +1.844-886-3118 Pop-up windows are small dialog boxes that appear +1.844-886-3118 automatically on the screen. Sometimes https://mssupport.tech/ these windows appear in an uncomfortable position and block important content. In such cases, moving the pop-up window becomes necessary.+1.844-886-3118 The easiest way to move a pop-up window is by using the mouse. Place the mouse cursor on the title bar at the top of the pop-up window. Click and hold the left mouse button, then drag the window to the desired position and release the button.+1.844-886-3118 https://mssupport.tech/ If the mouse does not work properly, the keyboard can also be used. Press Alt + Tab to select the pop-up window, then press Alt + Space. A menu will appear. Press M for Move and use the arrow keys to move the window. Press Enter to place it.+1.844-886-3118 https://mssupport.tech/ If you have any questions, feedback, or need support, please feel free to contact us using this form. Just enter your name, email address, and message, and our team will get back to you as soon as possible. Your feedback helps us improve and serve you better +1.844-886-3118 Cita
