heryyy
Tutti i contenuti di heryyy
  1. I completely understand your frustration with filament sticking to the nozzle and affecting extrusion during printing. To address this issue, I recommend considering a few factors. Firstly, inspect the condition of the nozzle for any signs of damage or wear. Secondly, ensure that the flow regulation is consistent and properly calibrated. Lastly, it might be worth experimenting with different types of materials or adjusting print settings to optimize performance. By exploring these possibilities, you can identify the root cause of the issue and implement the necessary steps to improve your printing experience. Best of luck!
  2. Hey there! I understand your frustration with the printer issue. Despite replacing the motherboard and trying different motors, you're still experiencing problems with the extruder. To troubleshoot, double-check the wiring connections, ensure a stable power supply, and inspect for any loose or damaged cables. Additionally, review the firmware settings on the motherboard. If the issue persists, seeking advice from experienced users or reaching out to the manufacturer might provide valuable insights. Don't give up just yet, we're here to help you get to the bottom of this!
  3. Good morning! I understand your frustration with the Y-axis movement issue on your Anycubic Mega Pro printer. Despite taking several troubleshooting steps and seeking support from Anycubic, you haven't found a solution yet. In addition to the recommended actions, you can try checking the wiring connections, verifying the power supply, and examining the Y-axis stepper motor. It's essential to keep testing and exploring different possibilities to identify the root cause of the problem. Don't hesitate to reach out to the Anycubic community or online forums for further assistance and insights. Good luck in resolving the issue with your printer!
  4. I'm sorry to hear that you're experiencing issues with your prints. It can be frustrating when something that used to work well suddenly stops performing properly. After replacing the FEP film, you've noticed that the prints are coming out misaligned, deformed, or sticking to the vat. There could be several factors contributing to this, such as bed adhesion, printer calibration, and resin quality. I would suggest checking the calibration of your printer, ensuring it is properly leveled and that the print settings are accurate. Additionally, double-check the adhesion properties of your printing surface and consider experimenting with different types or brands of resin to see if that improves the results. Don't hesitate to reach out to the community for further assistance and troubleshooting. Hang in there, and I hope you find a solution soon!
  5. Congratulations on your first resin print! It's understandable that you had some difficulty with the supports sticking to the build plate. One thing you can try is decreasing the exposure time for the first few layers to make it easier to remove them. Softening the resin with heat is another option, such as using a hairdryer to warm it up or soaking it in warm water for a short period of time. However, be careful not to overheat the resin, as this can cause it to deform or melt. It's great to know that you're using Anycubic wash+ water washable resin, which is a popular choice among 3D printing enthusiasts. Keep experimenting and learning, and you'll soon become an expert in resin printing.
  6. To change the loading speed of your 3D printer, you will need to modify the gcode file used for printing. This involves adjusting the feed rate setting in the gcode. However, before making any changes, it's important to check for other issues that may be causing uneven extrusion, such as clogging or a faulty extruder. If you find that the extrusion is too fine, it could be due to the extruder tension being too tight. To fix this, you can try loosening the tension on the extruder.
