Samu90
Tutti i contenuti di Samu90
  1. It was just like you said. I spent an hour trying to change the firmware, but it really had nothing to do with it. Thanks a lot, you saved me a lot of more time!
  2. CODE G START: M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk M220 S100 ;Reset Feedrate M221 S100 ;Reset Flowrate G28 ;Home G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line G92 E0 ;Reset Extruder G1 Z2.0 F3000 ;Move Z Axis up CODE G END: G91 ;Relative positioning G1 E-2 F2700 ;Retract a bit G1 E-2 Z0.2 F2400 ;Retract and raise Z G1 X5 Y5 F3000 ;Wipe out G1 Z10 ;Raise Z more G90 ;Absolute positionning G1 X0 Y{machine_depth} ;Present print M106 S0 ;Turn-off fan M104 S0 ;Turn-off hotend M140 S0 ;Turn-off bed M84 X Y E ;Disable all steppers but Z
  3. Hi! yes I use Cura. Where can I find the end-gcode pls? After the update, by the way, I am no longer able to control the printer via Cura. And to print I'm just using the SD card.
  4. Hello, I'm new to the forum. I installed version 1.1.9 Marlin on a Creality cr-10. My problem is that when the machine finishes printing, the Y axis is positioned opposite to how it was positioned before.Having already built a wooden enclosure, the Y axis directed in the front position hits the door.If I send to Auto Home from the LCD display the direction has remained unchanged since before the update and therefore it goes to the back position, which would be the position that should also go at the end of the print. How can I change the direction of the Y axis in the firmware only for automatic positioning at the end of printing?I thank everyone in advance. Samuel
