3d-beppe
Tutti i contenuti di 3d-beppe
  1. Vendo questa stupenda stampante Rostock Mini Pro con nozzle da 0.2mm appena assemblata, fornisco con Bobina da 1Kg di PLA arancio fluo e porta bobina in plexiglass. Fornisco su richiesta foto della stampante e degli oggetti che ho stampato per la calibrazione. Per qualsiasi domanda contattatemi senza problemi anche a info@3d-beppe.com Prezzo 590,00€ trattabili. Seguono caratteristiche: Rostock Mini is a delta 3D Printer originally designed by Bwevans, with smaller build volume compared to a Rostock or Kossel, but much more compact, portable, and desktop friendly. 3dprinterczar improved Rostock mini with carbon fibre arms, Traxxas 5347 u-joints, and a planetary gearbox extruder. The top and bottom plates are made from 6mm acrylic sheet to give strong support of the entire frame. This is a complete kit that contains everything (including tools) to build a Rosotck Mini Pro. The mechanical part can be finished between 3-6 hours depending on your experience with RepRap machines. Technical Details Build Volume: 18cm x 18cm x 20cm cylinderHeatbed: No (PLA is the recommmended filament).Extruder: Bowden extruderElectricalAny RepRap controller supporting 4 steppers and an extruder.12V 10A laptop power chargerNema 17 motors with 0.55 N*m torque x 3Nema 17 motor coupled with a planetary gearboxJ-head MKIV hotend 0,2mmDisplay: 3.0" 2004 LCDVarious Forming the largest size: D(Diameter)170mm* H(High)205mm Vertical print speed: 100cm³/h Forming accuracy: XY:0.012mm, Z:0.004mm Layer thickness: 0.05mm-0.4mm Offline Print (SD Card): Support Device size: 300mm*300mm*550mm Device weight: 4.2 KG
