Resnick
Tutti i contenuti di Resnick
  1. Ho scaricato Arduiono 1.0.6 e la compilazione non mi da errori. Quando provo a fare l'upload va in errore. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer Da quello che ho capito possono essere molte le cause. Penso che proverò a caricare il bootloader. Quale devo scaricare?
  2. Ho scaricato il firmware e provato a compilare ma ho degli errori. Uso IDE 1.8.5. Arduino:1.8.5 (Windows 7), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from sketch\ConfigurationStore.cpp:3:0: sketch\temperature.h:157:42: warning: extra tokens at end of #ifdef directive #ifdef THERMAL_RUNAWAY_PROTECTION_PERIOD && THERMAL_RUNAWAY_PROTECTION_PERIOD > 0 ^ In file included from sketch\Marlin_main.cpp:42:0: sketch\temperature.h:157:42: warning: extra tokens at end of #ifdef directive #ifdef THERMAL_RUNAWAY_PROTECTION_PERIOD && THERMAL_RUNAWAY_PROTECTION_PERIOD > 0 ^ sketch\Marlin_main.cpp:2126:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix] LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF"."); ^ In file included from sketch\SdFile.h:27:0, from sketch\cardreader.h:8, from sketch\Marlin_main.cpp:44: SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct' struct fpos_t { ^ In file included from sketch\Marlin.h:10:0, from sketch\Marlin_main.cpp:30: c:\program files\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here __extension__ typedef long long fpos_t; ^ exit status 1 using typedef-name 'fpos_t' after 'struct' MA se modifico fpos_t con filepost_t (ho trovato su internet questa soluzione) l'errore diventa questo: Arduino:1.8.5 (Windows 7), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" In file included from sketch\Marlin_main.cpp:42:0: sketch\temperature.h:157:42: warning: extra tokens at end of #ifdef directive #ifdef THERMAL_RUNAWAY_PROTECTION_PERIOD && THERMAL_RUNAWAY_PROTECTION_PERIOD > 0 ^ sketch\Marlin_main.cpp:2126:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix] LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF"."); ^ sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::getpos(fpos_t*)': SdBaseFile.cpp:298: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}' pos->position = curPosition_; ^ SdBaseFile.cpp:299: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}' pos->cluster = curCluster_; ^ sketch\SdBaseFile.cpp: In member function 'void SdBaseFile::setpos(fpos_t*)': SdBaseFile.cpp:1496: error: request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}' curPosition_ = pos->position; ^ SdBaseFile.cpp:1497: error: request for member 'cluster' in '* pos', which is of non-class type 'fpos_t {aka long long int}' curCluster_ = pos->cluster; ^ exit status 1 request for member 'position' in '* pos', which is of non-class type 'fpos_t {aka long long int}' Come devo modificare?
  3. Ciao a tutti Ho comprato una stampante Prusa i3 pro B MK8 della CTC. Vorrei apportare una modifica al firmware per abilitare i finecorsa MAX. La scheda è una GT2650 rev.A con caricato Marlin 1.0. Ho cercato sulla rete che dovrei modificare il firmware ma ho alcune perplessità. Per aggiornare il firmware della stampante devo aggiornare anche il bootloader? Da dove devo scaricare il firmware? Ho trovato molte varianti ma non arrivo a capire quale è consono al mio modello. Ho solo un estrusore e non ho interesse a mettere il secondo. Devo disattivare il secodo estrusore? Pensavo di cambiare estrusore con uno full metal. Devo apportare qualche modifica al firmware? Chiedo scusa per le troppe domande ma vorrei capire bene prima di procedere e commetere qualche errore. Grazie
  4. Resnick
    Saluti
    Buon pomeriggio a tutti E' da tanto tempo che seguo il mondo della stampa in 3D e le enormi potenzialità che ha da offrire. Un mese fa ho comprato una stampante CTC per fare vari esperimenti. Mi congratulo per l'ottima piattaforma online che mi è stata d'aiuto per i primi approcci alla stampa. Spero di imparare cose nuove a riguardo.
