Hej together & 0xdeadbeef
thanks a lot for the amazing converting tool:)
I updated and tweaked your provided Cura (and Slic3r) profiles for high quality prints up to 40/50 microns. Only tested with ABS (Z-ABS and others) on M200
1. Now the Cura profile prints ABS pretty good up to 40microns resolution / also changed build plate adhesion settings to Z-Suite standard
2. The Slic3r (PrusaEdition) also works with the variable layer height tool from 0,5 to 0,05mm / also changed build plate adhesion settings to Z-Suite standard (as far as possible)
Cura_Config_M200_40microns.curaprofile
Slic3r_config_M200_flexheight_50microns.ini
